Indicator light blinking continuously after image taken
Does your computer have a free usb port? If so, you should be able to use an external card reader (either type a or type c connector — the same as your computer’s port) plugged into the computer to put the firmware update on the camera's card and then upgrade the camera. These readers are fairly easy to find, even big box stores carry them for a variety of budgets. Or, you can find them online as well. p.s. Welcome to the forum.
Trying to update the firmware on my camera, and can't use the sd card method, as my computer has no card reader. I have to use the older Camera Remote app, due to my current firmware, but although the app finds my camera after proceeding in the 'pairing registration' section (detected the camera below), when I tap to connect it comes up with a 'pairing failed' message. It says 'reduced connectivity, place camera and smartphone closer together'. They are literally touching each other! I have tried everything - resetting the network, reconnecting both the camera and phone to the wifi, turning bluetooth on and off again, etc. As I say, my phone finds the camera straight away, but just can't connect. So now I am stuck in a vicious circle of not being able to update the firmware, nor update to the new Fujifilm X App. Has anyone any ideas?
replaced cables updated firmware defined the right connection at camera no matter what I have done, could not get it to be recognize. what to do?
The Laowa 65mm is a solid choice for product work; it's sharp, has minimal distortion, and offers excellent close focus. If you ever decide you want AF down the line, the Fuji 80mm f/2.8 is excellent but a lot pricier. For your budget and needs, I recommend the Laowa.
That sounds frustrating, especially after sticking with it since launch. Have you tried the latest firmware updates? I’ve seen a few XT5 owners say it helped with shutdowns and AF quirks, though low-light still seems to be a weak spot.
