Hi everyone,
I recently got a XT30 II and I can't open the raw files in Camera Raw's latest version. I checked on Adobe websites list and the camera is shown as supported on their list. Anyone here having the same issue. Is that a bug ? the camera needs a firmware update or I just the need to wait for a new update of Camera Raw. I would love to get if you have information on that or any possible solutions.
Thank you very much
