Gloucester with X-Pro1 18 & 27mm
By MARRIEDGUY9 · Posted
Practicing handheld shots, panning with slower shutter speeds to show motion and still freeze the subject details...........I got these down to 1/20 and 1/15 sec, 150-600 at 150mm, xt5. Fun to try.Welcome, dear visitor! As registered member you'd see an image here…
Trap Pond State Park, DE.......cypress trees on a calm day. 16-80mm.Welcome, dear visitor! As registered member you'd see an image here…
