Hi all,
Second post here would appreciate the input. I just purchased an X-T3 and X-H1.
The EVFs on paper are meant to be the same with same refresh rates when in boost mode.
The sizes are also meant to be almost exactly the same at 0.50 inches X-T3 and 0.48 inches X-H1 with the same resolution.
However the X-H1 EVF feels smaller (bigger black border around the edges) and not as clear. It also gives me eye strain after just a few minutes. (I have adjusted diopter). It feels like its further away if that makes sense?
Has anyone else noticed a difference between the EVFs when using them side by side because on paper they are meant to be the same. Perhaps its just this particular X-H1.
Thanks,
Fuji claims that it is exactly the same EVF (Sony-made OLED), but to my recollection the refresh rate of the X-T3 is a bit higher. The main difference (re. the EVF) is the processor of both cameras. The X-T3 has a later generation processor that allows for higher refresh rates. Make sure both cameras are in 'boost' mode when you compare them. Also other features (like brightness and color setting) can cause difference in EVF experience as well as minor changes in the optics in front of the EVF. Fuji isn't specific about changes re. this.
I can't compare anymore since I sold both cameras and switched. From that experience I can tell that the same EVFs on paper can make a great difference in practice. So, always check the EVF yourself before you buy a camera. Esp. when you wear glasses or need to change the diopter.
Edited by Herco
    • I repeat - there is something wrong. I have the same lens and an x-t5 and do not experience any sharpness problems. It may be that there are problems with a 150-600 lens, I don't  know, but mjoseph67 is using the 16-55. Make sure the af is set to focus priority and that you do not have af with mf set (if you have you could be accidentally moving the focus ring after autofocus). If that doesn't help get your camera and lens checked out.
    • Perhaps matrix/evaluative metering mode would be a better choice in more circumstances. We need to be aware of how the camera will see the scene and choices it might make, I find having the viewfinder set to "exposure preview" or whatever it's called is helpful in knowing when to apply exposure compensation.
    • This is what I found on a firmware update that seems to address the problem. However, firmware version is at Ver. 211 already. As stated above this occurrence only happens using the EVF and at apertures between f2.0 and 3.6. It does not happen using the OVF or LCD. The firmware update Ver.2.11 from Ver.2.10 incorporates the following issue: The phenomenon is fixed that when pressing the shutter button halfway under certain conditions, the live view can flicker.
    • Hi! Thanks for this comment! Yes, although I'm utterly happy with my X-T50, small, light, sharp pictures, Xapp functioning, I've got to know that the camera tends to emphasize contrast in contrasty scenes. In a way this is strange to me, as X-T50 mostly exposes very well. This is especially expected with photos with foliage. Of course, I would like that the behaviour would be different. When I'm taking travel and such pictures I choose for JPG format (not HEIC, as Mac's Photos opens them oddly very slowly; iPhone's HEICs open fast ...). With JPG I've chosen to use the DR400 setting, but the problem is still there. For "more important" photos I of course use the RAW format. Regards, T.
    • Congrats on your Fuji! Since the receipt is in your relative’s name, they’re technically the original owner for warranty purposes. Some manufacturers, including Fuji UK, may allow a warranty transfer if you contact them and explain it was a gift. You could either ask your relative to make any initial claim, or reach out to Fuji to register it under your name as the recipient of a custom gift. Since it hasn’t been registered yet, it’s a good time to check with them.
