Hello,
Totally new to photography. Got an XT4 as entry point wanting to learn.
As a starting point I've just used everything on auto. Set stills to highest quality (but not using RAW).
When I take film, it's awesome great quality, just what I'd expect. If I take a still of the same scene the results are totally different. Colours way less vivid, almost washed out and cropping loses quality quickly, like it's way lower res.
I've scoured the internet for what I'm doing wrong - but I'm out of my depth very quickly. I was just expecting 'decent' images with everything auto. Most tutorials I've watched don't really explore everything auto.
Using a Fujion XF 18-55mm Lens.
Any guidance on where to start?
Many thanks!
PC
Edited by Danstall
Typo
  • Danstall changed the title to XT4 Film great, stills washed out and blurred
Could you either provide a link to an original image (straight out of camera with metadata intact) or take a photo of the top of the camera and rear screen with camera turned on. We might get some ideas from your settings.
You could try going into the setup menu and run a reset in case you have accidentally changed some setting.
Couple of most likely settings.
Re. sharpness/blurriness: set the AF mode to AF-S (front of camera) and in the AF menu the AF mode to single point. Now take a photo with one object in the center covered by the green focus box. That object should be tack sharp in the photo unless your shutter speed is really low (below 1/30th). In the IQ menu set the image size to L 3:2 and the image quality to F or F+RAW.
Re. washed-out colors: press the Q button - set the film simulation to STD (Provia) and make sure that color is set to 0. S-Tone and H-Tone should be no more than -1 or +1 and switch Grain off. Make sure that you set White Balance to Auto, the aperture and shutter speed ring to A and switch on Auto ISO.
With these settings you should at least get 'normal' images. You have to check these on your computer. The LCD on the camera is not very accurate. If you did check the images on the LCD make sure that in the Set Up menu under Screen Set Up, the LCD brightness and color are set to 0.
Many thanks - something worked as it is much better now.
Great. I'm sure you don't plan to read the manual, but on YouTube there are some video tutorials to cover the basis settings.
Just type in "setup fujifilm xt4" in the search box.
You can set the colors of your stills to your liking: Chose film simulation (example: vivid), chose contrast (example: highlights +1, shadows +1), chose color (+1??).
Question-Marks because I think that's not necessary. Probably "Someone" chose filmsimulation PRO Neg. Standard for you. Or "Advanced" and some weird setting is opted on your camera.
    • More testing of lenses today.  Nikon 70-200 f/2.8 IF ED VR (same applies to VR II) - dreadful. Heavy vignette at all focal lengths and apertures. Obvioulsy fine in 35mm mode.  Nikon 70-200 f/4 - some vignetting at full frame (similar to 24mm f/1.8 and Sigma 105 f/2.8 so probably correctable or slight crop to 80-90MP). Perfect in 35mm mode.  If weight is an issue for you the kit 35-70 Fuji GFX lens is lightweight and better than you might expect but isn't a fast lens at f/4.5-5.6
