Stacking or bracketing? There's a difference. Bracketing speed depends on the lens being used and number of steps. As far as I know none of the Fuji models does stacking, only bracketing, the Olympus does both with a selection of lenses. In my humble opinion the micro-FourThirds system is better equipped for focus bracketing and -stacking. While I love my Fuji cameras for landscape photography I still use my micro-FourThirds system for close-up / macro and tele photography.
