My new GF 63mm lens works perfectly until I attach the Lee Universal lens shade with a filter attached.  The total weight is around 300gm, but while auto focusing or even manual focusing the Fuji GFX 100s comes up with an error requiring me to turn off and on the camera.  Has anyone else ran into this issue.  I would assume its due to the external focusing of the lens rather than internal.
