On1 2021 v Capture One
Comparing On1 and Capture One.
There seems to be much concern about which software does a good job of Fuji files.
Having decided to use On1 2021 I decided to compare a raf file (Fuji X-S10) with minor editing between these two editors. The photo in question is quite dull in keeping with the weather.
I only did the following to the file in both editors:
Pushed out the whites and blacks for max dynamic range
Boosted Structure (to 40)
Sharpened.
Having edited the file in each editor I exported the raf file as a full size jpeg and then compared them side by side in ACDSee Ultimate at 100%.
The attached comparison image was captured using ACDSee Ultimate at 100%.
The Capture One image is on the left and On1 is on the right.
I concentrated on the rocks as this is where I thought there may have been a problem.
I see no noticeable difference.
I hope this is of some interest,
Dave.
Hello Dave,
It is interesting to see although doing these comparisons can be quite a tricky science as different software engines will have differing incremental scales on any adjustment. I have seen this comparing Fuji rafs in C1 Pro and LR which is why I think its important to make use of the trials to help decide. How are you getting on with the X-S10? Wondering if you have tried it with primes and also if you have found the IBIS an advantage?
Will be down your neck of the woods over Xmas waving a 100v about!
John
I agree, best approach is to download a trial and try it out.
I have found the ibis lets me hand hold down to about half a second, below that and it is no longer sharp. Of course the lens also has IS so I may have managed with that alone but there is so much more to this camera than IBIS.
I only have the one lens, the 16-80mm f4, and I am very pleased with it. It balances nicely with the camera.
The weather here has been quite dreary since I got the camera so you can imagine the kind of photos but I am impressed by how accurately the jpegs reflect what I actually saw. The only time it got it wrong was a seascape where the white balance was very blue. I put this down to being in Auto WB but changing to Daylight WB did not improve things.
The Acros film sim is as good as I have heard on the forums.
Enjoy your Christmas trip.
    • Thanks for the replies everybody. But unfortunately that Amazon link says nothing about how to turn off the Fujifilm X-T20 WiFi signal receiver. I just want to know if there IS an option to turn it off. Otherwise I'm going to have to resell this beautiful camera and go back to a (lightweight) Nikon DSLR, such as the D3500 which I understand has very well behaved IQ results.
