Inresolved issue - Blackout picture
Did you use a card or cable direct from camera?
By Maplecameras · Posted
I had the same thing happen on my X100F. The fix for me was just pressing the shutter button a bit harder. After you half-press to lock focus, make sure to press down firmly and it should fire right away. If I press too lightly, mine still lags sometimes. Seems like it might just be the way the shutter button is designed, or maybe some wear over time. -
Hey , same problem here - did you find the cause or what the issue was? Was it the SD / CFast card? Thanks
See the response on the other forum - you likely had the camera set to save jpg only
Hi, I was going to get a xt5 today but I wanted to try it out before I buying it and I found one thing I couldn't solve: activating multiple exposures saves only the final jpg and not the intermediate raw. I couldn't find the solution, so in the end I left it there. Now the doubt came to me: wasn't it maybe set to save only in jpg and so it didn't save the intermediate shots because of that (although it seems absurd to me)? If any of you have it can you tell me if setting it to raw+jpg saves them? Also I noticed (and the guy at the store as well) that when you turn it on, the menu button doesn't work for the first 5/6 seconds. Does yours do this too? Thank you very much
