Just happened to see late in evening yesterday, July 31 2020, that it was "interesting" sky and absolutely calm on the surface of this lake, and I had the camera with me, so... I'm just learning to use my Fujifilm X-T4... Not easy task to take photos that is reasonably sharp in the evening but this one is OK for me...
/Bo
Edited by bem
