Hi Everyone!
I have a Fuji XT-30 and I am looking to tether my camera to my Mac to be able to utilize Lightroom.
I have found this wonderful software called "FUJIFILM X Acquire" but I am unable to get it to work. I can backup my settings on my camera to my Mac but I cannot specify a "Destination Folder" it is greyed out.
I also do not have the option on my XT-30 in my SET UP > CONNECTION SETTINGS > CONNECTION MODE to select any tethered options. I only have:
  1.  USB CARD READER
  2. USB MOVIE SHOOTING AUTO
  3. USB MOVIE SHOOTING FIXED
  4. USB RAW CONV. /BACKUP RESTORE
I was wondering if any of your have utilized this setup or if there is alternate software i should be using.
Also, I was wondering if i should be connecting via Micro HDMI port or the USB C port on the XT-30?
Any help will be greatly appreciated!
Currently on:
  • macOS Catalina 10.15.5
  • FujiFilm Firmware Version: 1.20
Edited by Ryanito13
  • 10 months later...
On 6/23/2020 at 12:57 AM, Ryanito13 said:
Hi Everyone!
  1.  USB CARD READER
Currently on:
please post this in fujifilm x-t30 section. there is a thread for this !
On 8/7/2020 at 2:27 PM, redders said:
The X-T30 doesn't support tethering :(
x-s10 didn't have either, now it's supported and there is a thread in fujifilm x-t30 for feature request, if you have one, comment there . have a nice day !
