Hello guys,
I'm very excited to receive my pre-ordered X100V (placed with my local store), but does anyone has experience which vendor usually delivers pre-orders first? Amazon, BH, or others? I'm a little impatient lol. I speculate the difference in delivery time will not be more than a week unless Fujifilm USA prioritizes some vendors over the others.
