Hi, I'm new to Fuji cameras. I noticed that Fuji lenses have a 35mm equivalent on X cameras. For example, the 56mm is the equivalent of an 85mm on a 35mm camera. Why is this? Would it not be better to have an 85mm lens that works as a 85mm on the APS-C sensor?
Thanks
Carlos San Miguel
This is not unique to Fuji. All cameras with APS-C sensors have a "multiplication" factor as the sensor is smaller than those on full-frame cameras, whose sensors are the same as the 35 mm standard. With Nikon, it is 1.5 times the lens (e.g. a 50 mm lens on a D7100 is equivalent to 75 mm full frame); with Canon its a 1.6 factor for their APS-C lenses (50 mm is equivalent to 80 mm full frame). You can't have a 85 mm lens be 85 mm equivalent unless you have a full frame camera. Make sense?
No Fujinon FX lenses are for use on X mount cameras only! A crop factor of 1.5 is applied to the engraved focal length to give the equivalent focal length if used with a full frame camera, which they can't!
Fro instance the crop factors are -
CSC = 1.5 FF = 1 mu4/3 = 2 it all depends on the size of the sensor!
I.e. An FX 23mm f1.4 is the equivalent approx to a 35mm lens on a full frame camera
Fuji use the code FX for their lenses only
Edited by Mike G
There's only confusion because people keep referring to 135 film equivalent as "full frame". Ironically that was small format film when introduced ...
Your lenses don't change. But your actual field of view changes with the sensor format. It's like cropping a larger picture; it is still taken with the same lens, but you get a smaller field of view.
Equivalence values are a tradition in photography.
They are at least ever since there were cameras around with a sensor smaller than 24 x 36mm, which was the size of the analog film, first invented for the moving pictures cameras and then used by Oskar Barnak when he invented the LEICA camera around the film format in order to use the widely available double perforated film.
Conventionally the “ standard lens" value is give by calculating the diagonal, in millimeters, of the format. The les closest to this value is the so called “ standard lens”.
Of course once you change the format this values also change but traditions are hard to kill.
So people still refer to the values relative to 24 x 36mm (or full format) simply as a mannar to communicate. So the 35mm ( which on a FF would be a medium wideangle) is the “ standard” lens on the APS-C used by Fuji.
Really there are some consequences also concerning the relative aperture and sone like to point this out, but frankly this is a rather useless exercise.
You are right, it would be better to use another way to talk about lenses like for example the field angular view ( how many degrees of an angle the lens shows) and refer to it alone.
But traditions are hard wearing.
Of course nowadays there is a generation ( and maybe OP is one) of photographers who were born when film cameras were already gone and don’t even know what a 24mm was on a 35mm film camera.
I found this: "The 35 mm equivalent focal length of a particular lens–sensor combination is the focal length that one would need for a 35 mm film camera to obtain the same angle of view."
https://en.wikipedia.org/wiki/35_mm_equivalent_focal_length
So, if my Fuji 56mm lens has an 85mm equivalence, then I would need an 85mm lens on a 35mm camera to achieve the same angle of view as the 56mm on the Fuji camera. I think I got it. :-)t
  • 11 months later...
The equivalence refers to a) angle (field) of view B) aperture size. As the sensor is 1,5 (approx.) smaller, the angle of view is also smaller, and aperture is also smaller. Imagine the A4 print as equivalent of full frame. Now the APS sensor is just rectangle in the middle not covering the whole A4 print (the . Which means that the APS sensor, from the same perspective and distance, "sees" less of the picture (and light gathering is also "weaker"). So in terms of length of the optical system (lens) is the same as in full frame (35 mm is always 35 mm :) but angle of view and light gathering capability is smaller. So using APS compared to FF gives you: a) "zoom" effect" B) larger depth of field (smaller aperture). kind regards, mat
  • 1 year later...
Fuji uses the XF destination not FX
On 2/6/2017 at 11:52 PM, csm said:
So, FX lenses are for FF cameras? If I was to mount the lens on a FF it would work as the mm engraved on the lens?
Thanks
yes Nikon FX lenses are Full Frame (FF) the numbers you see engraved will work on full frame mounts
however for crop lenses like Fuji's X-mount (aps-c) you have to calculate the 35mm (FF) equivalent ie: a fuji 18- 55mm (x 1.5) would be equivalent to 27mm -82.5mm full frame lens
Edited by Tim Pierce
some minor corrections
    • Thanks...Olaf yep confirmed....If I do the long press the menu appears and stay there until I release. Terry
    • Thanks...Olaf If I do the long press the menu appears and stay there until I release. Will retry again when home. Terry
    • Thats strange - I have the same camera and latest version of X Raw Studio (1.28.0.2) and it works as expected (using a Mac). Have you tried looking again at the old raw files that you viewed in the past and were working? That way you know its not something specific about these new files. There was a problem with the previous version of X Raw Studio and the latest release of the Mac operating system but that seems to have been fixed.
    • Hi all, It is my first post here. First, I'm not sure if this is a silly issue, but I couldn't find any help online, so I thought I'd ask here in case anyone knows how to solve it. Sorry if this seems trivial or simple to correct. I had no problems before and was using the software just fine for more than a year. However, it suddenly started not recognising my files (?). As you can see, I select the folder where I transferred my files from the SD card, and nothing shows. The camera is connected and updated. I'm using the latest version of X Raw Studio as well. I tried deleting all the photos from the folder and transferring them again directly from the SD card, but nothing has changed. Has anyone experienced this before? Any tips on what I might be doing wrong and how to fix it? I uploaded two images to show you what is happening.  Thanks!
    • Welcome! I‘m pretty sure you had to long press the OK button with the X-T2, and it works the same with other models
