OK so I did more testing as I have both the X-T1 and X-T2 currently. I can place the Cactus V6II trigger on the X-T1, long press the scroll wheel and it enters "Forced HSS" and it works with the Cactus V60 flashes with no issues at very high shutter speeds. The X-T2 does not work at any speed if I use "Forced HSS" mode on the trigger.
Crossing my fingers and hoping for a firmware update to support the new Fuji HSS/TTL, I'm guessing after Fuji releases the updated HSS/TTL support for the X-T1.
Thanks for the link looks like they updated their info and the answer is NO :(
Camera(s) tested that does not support high-speed sync modes on the Cactus V6 II:
  1. - Fujifilm X-E2 (Updated: July 18, 2016)
  1. - Fujifilm X100T (Updated: September 7, 2016)
  1. - Fujifilm X-T2 (Updated: September 9, 2016)
Maybe it would be worth while to inquire with Cactus to ask if they plan on implementing via Firmware the ability to do HSS on the XT2.  Others (like me) would be interested to hear what you learn as it is a product I have on my wish list.
Thanks
I asked them (via Twitter) let's hope they respond. Half the reason I bought Cactus is because it works with Fuji and so many other brands and they actually push out firmware updates! I can only assume they need to analyze the new TTL modes on the X-T2 and then hopefully have an update.
