My current combination for shooting wildlife , waiting for the 100-400 ..  :D
Aswald,
if you already have the lens I think buying the ' ring it's worth it...  ;)
Ok thanks. I think I will ;)
I didn't have much luck with my other camera but I forgot that the Fuji is a 1.5x crop sensor.
  • 4 months later...
    • (Open Thread) Not a winter landscape, but still cold.
    • agreed on the upload but based on the location and number it sounds exactly like the storage slot 1 status icon
