Fujifilm GFX100 Firmware 1.02 Released
Fuji X Rumors
Fujifilm just released Fujifilm GFX100 firmware ver. 1.02, which incorporates the following issues: Change of switching setting of information display by DISP/BACK button Fix of exposure mode change in interval shooting Fix that a developed RAW file can become black…
The post Fujifilm GFX100 Firmware 1.02 Released appeared first on Fuji Rumors.
Full Article on Fuji Rumors
    • FYI Update - I just learned that the Zoom F6 & F3 recorder/mixers also synch to the UltraSynch Blue over bluetooth. I am planning to record 32bit float on the F6 and it will have frame accurate matching time-code with my two-XH2S' and one XH2.
