Hello, I have joined the Fuji X Forum today. I have been browsing for a while before I made the leap into buying my first FujiFilm camera.
I have a X100F arriving today, It is used, purchased from WEX photographic here in the UK. They rate it as 9 for condition and is complete with all the original accessories and the original box. The reason I chose a used one was down to cost and the fact that WEX offer a 1 year guarantee on the camera.
I have used point and shoots before, and the last few years the camera on my phone. I looked at DSLR and micro four thirds cameras, they didn't feel right for me, too big and loads of buttons and features.The X100F hopefully will suit me ( I have tried one in a store) before making the decision.
Thanks for reading this.
David
My two X100 series cameras (S later converted to IR) and F changed my life, photographically speaking.  I went from an occasional shooter, mainly on vacations to a photo nut.  And I love it.  I'm always thinking of where to go and what to shoot next. I don't always use the manual dials and buttons but when I need more control, it is so easy.
It is even better when you customize the settings.
I use ND and ISO on the front and Flash, WB, and Film Simulation on the back ring plus the quick focus button and magnify button.  I never use the Q button for anything.
If you enjoy yours even half as much as I enjoy mine, you will be thrilled.
