Where is the XF 16-70mm f/4 WR OIS?
hjalmarg1
I has been a while that there are no news of the upcoming XF 16-70mm f/4 WR OIS, what are the specifications (size and weight) for this lens? would it be a light weight lens?
This would have been the perfect companion for my summer holidays as all-around lens.
