I did a quick search and was surprised that nobody has asked about supporting Blackmagic's open source BRAW as a video recording/encoding option for Fuji cameras. I'm not a video RAW expert and I wonder if BRAW would support the X-Trans sensor information. With the processing power in some of the newer cameras like the X-T3, it seems like it would be a really great option to capture 10-bit video at lower bit rates.
Has anyone looked into this?
  • 11 months later...
Actually, I am curious if I can load Fujifilm LUT’s into a Blackmagic Pocket Cinema camera?
Honestly, I love working in BRAW! Somehow, Fujifilm can “get into bed” with BLACKMAGIC to collaborate on a cinema camera together would be a “DOPE” scene!!!
This idea would be the ultimate “wet dream!!!”
