I'm looking to buy the new 90mm, but I would like to see some RAW samples of the sharpness and the bokeh, if youäve got an XE1 that would be even better! Anybody want to provide a couple of untouched sample pics? Just shoot a wall or whatever, I just want to see the sharpness mostly :)
Thanks!
Problems with uploading. Here is another try.
Hi,
not RAW, but unretouched straight out-of-camera JPEGs from an X-E1:
All hand-held, but I used high shutter speeds so as to prevent any shake-induced blur.
1) First, one admittedly very boring shot of the gravel on a footbridge at f/4, just to show how SHARP this thing is!
'Astia' film simulation, DR = 100
View: original size
2) Then, a 'torture test' for CA: wide open, and backlit against an almost (but not quite) blown-out sky. Impressive control of all chromatic aberrations, and razor-sharp plane of focus.
'Astia' film simulation, DR = 200
View: original size
3) A 'bokeh' shot at f/2. Quite neutral and pleasant, IMO.
View: original size
4) Lastly, an indoor shot wide open at ISO 6400. Coming from film, I still find getting such high-quality and 'film-like' results at such high ISOs amazing...
'Negative High' film simulation, DR = 100
View: original size
Marco
