Two bodies for travel?
You may have to be a little more patient. There are some recipe users stopping by now and then and some X-T50 film sim dial fans that stop by now and then as well. Hopefully, one of them will be able to help you. p.s. Welcome to the forum.
By buellwinkle · Posted
Patric I have a Four By FIve mono rail Sinar Norma. When I bougt my Fuji 50R, I bought a digital back for my Norma with mount that attaches to the lens mount on the fuji. I have no yet used it but I think it holds some interesting promise. If I rembemer it was listed on the Fuji website..... hope this helps you.... Jim -
By ruralrelic · Posted
This is probably very obvious, but I am a little confused! - Presumably, when using the film simulation dial on the X-T50, the Custom Settings need to be set at 'Nothing Serlected@' Is this correct? Thank you -
The Laowa 65mm macro seems well regarded, I'm sure it would serve you well. Another potential choice would be the Fuji 30mm macro, but it would have a closer working distance and might make lighting your subjects harder.
