I'm new at this forum. I can't find topics about GPS when using the top search field. So if there are, please excuse me for this question and help me to find those topics.
I'm currently using Nikon gear for my travel. I am considering switching to Fuji for that.
One of the issues I have with Fuji is the possibilities of GPS tracking. For Nikon I use the GP-1 GPS unit connected to my main camera. That gives me a very accurate trail of GPS locations in all of my images from that camera. Especially when I'm shooting in nature reserves I like to know my location at the time of shooting.
As far as I am aware of now, Fuji does not have such a unit like the Nikon GPS or support one. There is a possibility to get a GPS connection from your smartphone but as far as I recall that's not on a regular base.
So I tried to use a GPS-app (GeotagPhotos2) on my iPhone and merge the GPS data later on in Lightroom. The merging part worked flawlessly but I was really disappointed by the sloppy accuracy of the iPhone.
How do you Fuji users get accurate GPS data in your files?
Have not read the manual? X-t3 For example has bluetoth and wireless to connect permanently to your phone and with applicaton software cam remote by fujifilm installed in your phone, when you take a picture, the camera records also GPS coordinates
The Fujifilm Bluetooth implementation on my X-E3, if enabled, will drain the battery overnight when the camera's power switch is turned off. Bluetooth runs continuosly. I'm not sure if this is an intentional feature or a bug. Do not know if the X-T3 has the same problem.
  • 1 year later...
I regularly record my tracks to GPX, and find it as accurate as civilian GPS allows. Turning on WiFi may help around town. I’ve been using an old MotionX app on my iPhone but there are newer apps that do the same. I keep  my phone near the top of my pack. I find this works better than using the tethered GPS unit in my flash shoe eating up my camera battery. Then, sync it in Lightroom later.
  • 2 years later...
    • I repeat - there is something wrong. I have the same lens and an x-t5 and do not experience any sharpness problems. It may be that there are problems with a 150-600 lens, I don't  know, but mjoseph67 is using the 16-55. Make sure the af is set to focus priority and that you do not have af with mf set (if you have you could be accidentally moving the focus ring after autofocus). If that doesn't help get your camera and lens checked out.
    • Perhaps matrix/evaluative metering mode would be a better choice in more circumstances. We need to be aware of how the camera will see the scene and choices it might make, I find having the viewfinder set to "exposure preview" or whatever it's called is helpful in knowing when to apply exposure compensation.
    • This is what I found on a firmware update that seems to address the problem. However, firmware version is at Ver. 211 already. As stated above this occurrence only happens using the EVF and at apertures between f2.0 and 3.6. It does not happen using the OVF or LCD. The firmware update Ver.2.11 from Ver.2.10 incorporates the following issue: The phenomenon is fixed that when pressing the shutter button halfway under certain conditions, the live view can flicker.
    • Hi! Thanks for this comment! Yes, although I'm utterly happy with my X-T50, small, light, sharp pictures, Xapp functioning, I've got to know that the camera tends to emphasize contrast in contrasty scenes. In a way this is strange to me, as X-T50 mostly exposes very well. This is especially expected with photos with foliage. Of course, I would like that the behaviour would be different. When I'm taking travel and such pictures I choose for JPG format (not HEIC, as Mac's Photos opens them oddly very slowly; iPhone's HEICs open fast ...). With JPG I've chosen to use the DR400 setting, but the problem is still there. For "more important" photos I of course use the RAW format. Regards, T.
    • Congrats on your Fuji! Since the receipt is in your relative’s name, they’re technically the original owner for warranty purposes. Some manufacturers, including Fuji UK, may allow a warranty transfer if you contact them and explain it was a gift. You could either ask your relative to make any initial claim, or reach out to Fuji to register it under your name as the recipient of a custom gift. Since it hasn’t been registered yet, it’s a good time to check with them.
