Hello everyone,
Does anyone please help me giving information about a camera which will be perfect for product photography. I usually take photos of products to sell them online. Need white or grey background against the photos. Please tell me which camera should I choose.
Thanks in advance
Any camera will do. Put more effort in the "stage". E.g. a seamless background sheet from paper and some light to fill the top/sides properly. All of this can be done with very, very cheap stuff (e.g. a large sheet of paper and two white construction or desk lights) and the camera can be a cell phone.
