Hello Herco,
My problem (1) seems to be caused by the combination of wireless flash trigger, GODOX X2T-F.
Today also I experienced "usual" busy status with orange signal, and it immediately turned green when I switch off the commander.
I am processing RAW file with Lightroom classic and Photoshop, and have CaptureOne, which I am not used to.
I am saving new investment on Fuji system now... and using EF lenses with Fringer mount adapter.
  • 4 months later...
I bought my X-H1 4 years after its release this January! The "Fuji Way" (menus, quirks and dials) took a bit for me to understand and to use on the fly in the field, but I love the camera now and especially the beautiful images.  If I can't get a nice photo with this camera and most any Fuji lens, trust me, it's me...not the camera! Quality feel, addictive shutter, superb EVF, etc.  The AF is quite a bit better than prior X100 series models I've owned and sold.  It is quite useable now for moving objects.  The X-H1 and a 23 f/2, 35 f/2 or 50 f/2 would be a superb walk around/travel camera...even in 2022!
    • Hey everyone, I am new to the fujifilm system, and I just received my X100vi about 15 days ago, and yesterday I noticed that ISO and exposure dials are acting up. I spent hours watching YouTube videos and reading forms without finding any solutions. Using ChatGPT or Gemini also didn’t help. My issues are the following: If I want to set my ISO at a specific value then the camera LCD/EVF shows a totally different value. For example, I have shutter manual, aperture manual and ISO dial at 6400, the camera shows ISO at 4000, when I take pictures it will show ISO at 4000 and not 6400. When I try to choose another ISO value it will skip some of the available values that are shown on the dial. Another issue I am having is when my exposure dial is not set at specific value, then I cannot set ISO to Auto no matter what value I select on the dial. If I do select the different exposure compensation values, then I choose A for ISO, the camera will activate the front commend dial to manually change ISO values. To get in Auto ISO, the shutter speed cannot be set in auto and the ISO dial should be set at 125, when I turn the ISO wheel, it seems like the numbers are misaligned by one value, If I put the dial on A with shutter speed manual, then it will trigger the front commend dial. The other issue that I am having is when I have Aperture, shutter speed and ISO on manual, If I change the exposure dial compensation + or - , it actually changes the exposure of the picture as well as the ISO value, which as I understand, if Camera is in full manual, the exposure dial should do nothing. The last issue that I am having, if I do have ISO in manual at a set value, and adjust exposure compensation dial, it alters my ISO instead of my shutter speed or my aperture, even though ISO is in Manual and the other two dials are in Automatic. I am not really sure if all of this is by design and I am just not understanding how everything works together, but it seems really odd how everything changes. Resetting the camera settings didn’t help.
