Hommes De Vase - Fleuve | Espace Danse
Better and better. You should experiment with rear curtain flash, if you have the chance and if possible. I don't know if it's a reharsal and one is allowed to use a flash
Thanks!
It's a Live General Performance...
No Flash Allowed...
It\s always a challenge...
Great pictures!. What lens and camera are you using ?
Thanks!
X-T2 w XF16-55mm 2.8
Single
JPEG
Zone Focusing - Set to Smallest Zone Focus Area
ISO Min 200 - Max 12800
Min Shutter Speed 1/500
Boost Mode Enabled
AF-C Custom Setting #2
No Flash
Transferred JPEG to iPad with Fujifilm Cam Remote App and Minimal Touch Up with Lightroom on iPad
I imagined it wasn't allowed using a flash. If you knew any of them it would be interesting trying to do some experimentations. Though you should find the right place.
It was a General Live Performance...
Quite the Challenge with them zipping across the stage with very low light...
X-T2 and 16-55mm are great tools to use but I need to do better...  :)
