I live about 400klm out of Vancouver, BC and will be heading down for a week and would like any suggestions on stores in the Vancouver area that are well acquainted with Fuji products (specifically accessories) for which my local shop has limited or none selections. Also can't forget the opportunity to chat up other Fuji enthusiasts (besides you good folks).
Thank you - jim
I live in Vancouver.
Moved from Calgary where the no brainer choice is The Camera Store.
In Van? I just go to any random London Drugs. They usually stock everything, but don't expect the clerk to know much. I bought my 56 1.2 there when they were impossible to find anywhere else
I echo London Drugs anywhere in Western Canada. When the X-Pro1 was announced and preorders became available, Vistek, Henry's and other major stores had hundreds of orders. For all of their stores combined, London Drugs had only 11 orders, so I got my X-Pro1 within a day or so of their arrival in Canada.
I live about a five-minute walk away from the closest store, and over the years, there have been many well-informed enthusiasts behind the counter. Certainly there were also people who just know how to ring up sales. The person I have been dealing with over the past decade or so, was primarily a medium-format shooter and very well informed. Since there seems to be a very low turn-over in staff, it is possible to build a long-term relationship. Also in their favor, they will match any legitimate advertised price in Canada, and you save shipping costs as well.
Interesting suggestions echoing my own experiences..  I bought my first Fuji, an XE-1 from LD and now a number of lens and the standard peripherals.  Here in Vernon, the shop is quite small, but they have always been eager to accommodate my queries and make my purchases as easy as is possible.  They will and do draw upon the stores in the area or from Vancouver.  One fellow that I get to deal all to infrequently is a strong advocate of Fuji and I quite enjoy working with him in solving any concerns or questions I might have.  I was fortunate to have Vistek and Henry's in TO for many years, and thus my query as I'm not that familiar with any Vancouver shops.
Thank you for your responses.
    • I just want to say thanks very much!  That worked a treat - did as said used ‘clean all’ command and then waiting a while for it to do its thing, once I put the card back into the camera and initialised then removed it and put it back onto the PC it worked and popped up as usual.  Somehow overtime all 3 of my cards must have become corrupted.  But doing this worked, again Many thanks  Here are the steps I took so that if anyone else runs into this issue they can fix it: 1.  Put express card into the reader and plug into pc (you should hear a sound, but the card will not mount).   2.  Run ‘Command Prompt’ as an administrator,  you can find it in Start Menu and right click then run as administrator.  3. type in ‘diskpart’ This will load the software, be careful here as you could accidentally format the wrong drive. 4.  when DISKPART> is displayed type ‘list disk’.   wait a while and a list of all disks on the system will appear, look for the disk that is the size, in my case it was 476GB.  double check this is the right disk as you will format and erase all content on this disk to make it work.  5.  type ‘select disk 3’  in my case disk number 3 was the right one. 6.  type ‘clean all’   it took mine about 15 mins to work, it looks like it is doing nothing but it isn’t, it’s doing a full format.  You will get a prompt ‘DiskPart succeeded in cleaning the disk’ 7.  Remove the disk and place back into fuji camera, then format/initialise as normal.  8.  eject disk and place back into PC and it should mount as usual.   Hopefully that works!
    • I haven't had any problem with my XH2s and CFexpress card, but I struggled for almost 1 year with a 256GB SD card . To cut it short : I finally solved the problem formatting the SD card using windows DiskPart command. I think the key was removing everyting from the SD card using the "clean" command. Diskpart is rather technical, I hope you can understand how to use it. Search google for :   "diskpart erase partitions" Hope this helps.
    • Hi,  i’ve had a look around the internet and can’t seem to find anyone with this issue.  Long story short is I used to be able to access my CF Express type B cards that are formatted by my XH2s on my pc and my mac.  They would pop up as an external drive through an external Sabrient reader.  Now they don’t?!  Has something changed in the firmware? something broken. A few observations: It now happens with all of my Sabrient cards. I bought a new Lexar reader and it does it with that too. If i format the cards on my RED camera and then mount on the computer they work fine as expected.  Once I put back in camera and format the card then place back to PC it doesn’t work. The only way i’ve been able to access the card is while it is plugged into the camera but this seems a lot slower to transfer data. Has anyone else noticed this? would appreciate any solutions.
    • Replied with samples on a different forum
