Hi there,
Quick question: when using two cards, after the first is full, is it needed to switch off the camera or does it automatically start saving on the card #2?
I'm asking this because on my wife's X-T2 at some point today she's got a warning on the screen saying to turn off the camera and then turn it on again.
I find myself wondering why you have set up the camera in this way, to write to one card first then to write to the other one.
What if one of the cards proves defective? There's more than one thread in this forum that relates to this being a potential problem.
Personal preference is to let the camera write jpgs on the one card, RAW on the other. Then I know I've got a backup against a defect occurring on a card, and with relatively frequent downloading to my PC, I'm covered against losing an image.
    • Hey everyone, I am new to the fujifilm system, and I just received my X100vi about 15 days ago, and yesterday I noticed that ISO and exposure dials are acting up. I spent hours watching YouTube videos and reading forms without finding any solutions. Using ChatGPT or Gemini also didn’t help. My issues are the following: If I want to set my ISO at a specific value then the camera LCD/EVF shows a totally different value. For example, I have shutter manual, aperture manual and ISO dial at 6400, the camera shows ISO at 4000, when I take pictures it will show ISO at 4000 and not 6400. When I try to choose another ISO value it will skip some of the available values that are shown on the dial. Another issue I am having is when my exposure dial is not set at specific value, then I cannot set ISO to Auto no matter what value I select on the dial. If I do select the different exposure compensation values, then I choose A for ISO, the camera will activate the front commend dial to manually change ISO values. To get in Auto ISO, the shutter speed cannot be set in auto and the ISO dial should be set at 125, when I turn the ISO wheel, it seems like the numbers are misaligned by one value, If I put the dial on A with shutter speed manual, then it will trigger the front commend dial. The other issue that I am having is when I have Aperture, shutter speed and ISO on manual, If I change the exposure dial compensation + or - , it actually changes the exposure of the picture as well as the ISO value, which as I understand, if Camera is in full manual, the exposure dial should do nothing. The last issue that I am having, if I do have ISO in manual at a set value, and adjust exposure compensation dial, it alters my ISO instead of my shutter speed or my aperture, even though ISO is in Manual and the other two dials are in Automatic. I am not really sure if all of this is by design and I am just not understanding how everything works together, but it seems really odd how everything changes. Resetting the camera settings didn’t help.
