Was in Las Vegas a few weeks back (Venetian hotel) and then Doncaster UK more recently and saw this art deco building. Took both shots with XE-2 and F2 28mm prime. Vegas is RAW + in-camera B&W conversion. Doncaster is same but then in-phone contrast boost plus vignette.
Sent from my SM-A310F using Tapatalk
