Hi,
I'm researching a gimbal to get someone as a present & they use a Fuji XS-10. I did a quick search of previous threads on gimbals but all of them seem to either get no replies or spammed by a link to an Amazon list.
I'd appreciate any comments from folks who've actually used specific gimbals with the XS-10. I'm aware that some, such as certain models from Zhiyun, DJI & FeiyuTech either don't say that they are fully compatible with the XS-10 but other sites say they do work ok but some functions don't. It's quite difficult to work out which functions work & which don't.
Thanks.
