XT2 freeze/locks up
stepwes
Hi all I am new to this forum.
My 3 month old XT2 when in electronic shutter mode with boost grip attached and set for 3 bracket (AE) ( I use this set up for candid street shots) the first press of the shutter shows the 1st shot taken in the EVF and is locked and no controls work inc ON/OFF
Detaching the grip resets it.
This has happened twice only as I now use mech shutter.
I have now updated firmware to ver 2 so will see what occurs
Can anyone shed light on this???
I had a similar issue but my XT2 would freeze in continuous low, instead of bracketing mode. Installed the new firmware and the issue completely went away. Hopefully you have the same luck with the firmware. If not, send it back to Fuji while it's under warranty.
