Not many people will have this combination of cameras, so not sure how many replies you will get.
Actually I wrote it just to let others know that X-A2 with 16MP bayer could be a better choice over X-T20 with X-Trans if you don't need extra 4K.
Probably even better than X-A3, I have a quick test of X-A3 comparing it to X-T20 ( I was deciding which to buy), so I took several shots with X-A3 and X-T20,
and X-A3 didn't give better results than X-T20, in some cases it was noisier. But it was a handheld shots, not from 100% exact position. So according to those shots I choose X-T20.
Probably not a good decision which I'm regretting now. Especially after I tested focus abilities of X-T20 in low light conditions. Which is almost identical to X-A2 if used with 56mm. 60mm, 90mm, 50-230mm
although it was pretty fast with 16mm 1.4, 30mm 1.4, much faster than X-A2.
  • 3 years later...
