Right now, there's no way to set the digital teleconverter when you're in MF mode, without diving deep into the menus. In AF mode you can set it to the control ring, but of course that's not available in MF mode, and currently you can't set it to a function button for quick access. I actually really like the digital teleconverter, and since I usually shot in Medium size mode, I don't get as much image degradation since it crops and then doesn't need to upscale as much, if at all. I'm in MF with back-button focus most of the time, since focusing is quicker and in AF/Av mode the aperture release is super annoyingly slow and flickers the LCD/EVF screen.
So, this post is mostly to get this on Fuji's radar, unless someone actually has found a way to do this. I gather they monitor this at least to some extent, and I'm sure this is an easy firmware addition if they choose.
You can set it as an item in your "My Menu" ... but that's only marginally better. I'd also like a way to assign it to a different Fn button. I didn't even expect to enjoy the digital teleconverter this much...
Which button did you assign as your back button focus? I ended up settling on the left selector, but I also considered the rear command dial (pressing it) and the metering button (Fn1).The AEL/AFL button seems too far but I might try that out as well.
I agree, I didn't expect to enjoy it nearly this much either. I think one thing that really helps is that I've found myself shooting sometimes in medium jpeg, and if you use the digital teleconverter in the smaller filesizes you don't get the upscaling as much (I'm assuming it does the crop first, then the resizing).
For back-button, I actually have it set in two places. I use the AEL/AFL button as well as the button that's on the EVF/OVF lever. That way wherever my hand is positioned, I have access to it a lot.
That said, I've found myself using AF mode on the X100F a *lot* more than I ever could on my original X100.
I set my BBF to the Rear Command Dial.  Just feels more natural there than the AEL/AFL or EVF/OVF buttons for me.
Very annoying to have to switch from M to S, from burst mode to STILL FRAME, and Fine+RAW to Fine for teleconverter use.
Also not impressed with not being able to back button focus in any mode other than Manual Focus.
This being my first Fuji camera, I was pretty confused for a couple of hours trying to figure out how to configure the X100F.
Canon has a leg up with the BBF, Fuji!
That said, this is still a very nice camera and I plan to keep it. :P
    • Hey everyone, I am new to the fujifilm system, and I just received my X100vi about 15 days ago, and yesterday I noticed that ISO and exposure dials are acting up. I spent hours watching YouTube videos and reading forms without finding any solutions. Using ChatGPT or Gemini also didn’t help. My issues are the following: If I want to set my ISO at a specific value then the camera LCD/EVF shows a totally different value. For example, I have shutter manual, aperture manual and ISO dial at 6400, the camera shows ISO at 4000, when I take pictures it will show ISO at 4000 and not 6400. When I try to choose another ISO value it will skip some of the available values that are shown on the dial. Another issue I am having is when my exposure dial is not set at specific value, then I cannot set ISO to Auto no matter what value I select on the dial. If I do select the different exposure compensation values, then I choose A for ISO, the camera will activate the front commend dial to manually change ISO values. To get in Auto ISO, the shutter speed cannot be set in auto and the ISO dial should be set at 125, when I turn the ISO wheel, it seems like the numbers are misaligned by one value, If I put the dial on A with shutter speed manual, then it will trigger the front commend dial. The other issue that I am having is when I have Aperture, shutter speed and ISO on manual, If I change the exposure dial compensation + or - , it actually changes the exposure of the picture as well as the ISO value, which as I understand, if Camera is in full manual, the exposure dial should do nothing. The last issue that I am having, if I do have ISO in manual at a set value, and adjust exposure compensation dial, it alters my ISO instead of my shutter speed or my aperture, even though ISO is in Manual and the other two dials are in Automatic. I am not really sure if all of this is by design and I am just not understanding how everything works together, but it seems really odd how everything changes. Resetting the camera settings didn’t help.
