Hi, I have recently upgraded from X-T1 to X-T2 and like the new camera a lot. However, I have a question about the AF-L button on the top right. On the XT1, I am sure that pressing this focussed and locked the focus, on the XT2 it seems to only lock OR focus but not both. So the only way is to press the shutter half way and then press the AF-L button to lock it, which is very fiddly. When in manual focus mode it does focus but does not lock as I would expect.
I have no idea what you mean by that :)
The button can be set up to lock the focus when it is pressed, and unlock it when pressed again. Or it can be set to lock only while pressed. I use it the second way.
I have both cameras and there is a difference... when the cameras are set to AF-S.  In this mode, the X-T1 acquires and locks focus when you press AF-L but on the X-T2 pressing AF-L does NOT acquire focus... it simply locks lens focus and prevents the shutter release from acquiring focus.  In AF-M mode the AF-L button works the same on both cameras.
Personally, I don't see why Fuji decided to make this change on the X-T2... its annoying and the reason for it escapes me.
Hmmmm ..  this seems a bit confusing.  I shoot with XT1 and XT2 at the same time when I'm at my weddings (#1 reason I do photography) and I have the AFL working the same way on both cameras.  When I press the AFL button, it acquires focus (I use AF-S for single point) and it holds/locks focus as long as I hold the button.  When I release the button the focus lock ends.
This lets me (on both cameras), lock the focus and lock it while I recompose or wait for the moment to happen.  Then I press the shutter button and I have instant photo (and a notably quicker capture on the XT2 versus the XT1).
I upgraded from an XT-1 to an XT-2.  When the AF-L button is depressed with the camera in AF-C mode, the camera acquired focus and locked the focus at that settin. The AF-L button in the XT-2 confused does not work the same way. In fact, it appears to work only as a back button focusing button in manual focusing mode. It does nothing in AF-S mode. Even if I focus in AF-S mode then switch to Manual mode, depressing the shutter halfway refocuses. I tried several combinations of settings in the Back Button settings for AF-L. It really does need a firmware change to allow the lock button as before.
I continued to play around with menu settings.  If use the settings below, the AF-L button will work like it did in the XT-1.  However, you lose back button focusing with the AF-L button. I the Button/Dial Settings: Shutter AF On; AE-AF-Lock Mode. AE & AF On Off Switch; In the AF/MF Section:  Release/Focus Priority: Focus.
When I set Button Dial Settings> Fn/AE-L/AF-L>Fn-2 to AF On, I am able to use it as a front button function in place of back button focus.
    • My very much loved X-Pro 2 has a serious problem for a long time but I can’t help myself, it’s too good to just sit on a shelf.    Last year the display had started weird pink colors and the camera was freezing after a few seconds. First I thought the screen was the problem but when I get into the menu at once, the screen looks fine. After some seconds or when I am trying to get the the configuration part of the menu, the camera will freeze again.    when I turn it off the screen stayed on for about a second. But I can’t turn it on again even after the screen finally went black. I need to remove the battery and insert it again and then I can turn it on again. But the problem is there again and again. today I saw that there was a new firmware update 5.11 that is said to fix a freezing problem and I thought to give it a last try. Ironically I could successfully make the firmware update with no problems. Somehow terrifying to make a firmware update when you don’t know if the camera might freeze during the process. But everything went fine. Problem is the same as before. I tried different batteries and different lenses and without a lense. Always weird pink colors on the screen and finally freezing. Any suggestions from the community?    Or perhaps help from Fuji?
    • I repeat - there is something wrong. I have the same lens and an x-t5 and do not experience any sharpness problems. It may be that there are problems with a 150-600 lens, I don't  know, but mjoseph67 is using the 16-55. Make sure the af is set to focus priority and that you do not have af with mf set (if you have you could be accidentally moving the focus ring after autofocus). If that doesn't help get your camera and lens checked out.
    • Perhaps matrix/evaluative metering mode would be a better choice in more circumstances. We need to be aware of how the camera will see the scene and choices it might make, I find having the viewfinder set to "exposure preview" or whatever it's called is helpful in knowing when to apply exposure compensation.
    • This is what I found on a firmware update that seems to address the problem. However, firmware version is at Ver. 211 already. As stated above this occurrence only happens using the EVF and at apertures between f2.0 and 3.6. It does not happen using the OVF or LCD. The firmware update Ver.2.11 from Ver.2.10 incorporates the following issue: The phenomenon is fixed that when pressing the shutter button halfway under certain conditions, the live view can flicker.
    • Hi! Thanks for this comment! Yes, although I'm utterly happy with my X-T50, small, light, sharp pictures, Xapp functioning, I've got to know that the camera tends to emphasize contrast in contrasty scenes. In a way this is strange to me, as X-T50 mostly exposes very well. This is especially expected with photos with foliage. Of course, I would like that the behaviour would be different. When I'm taking travel and such pictures I choose for JPG format (not HEIC, as Mac's Photos opens them oddly very slowly; iPhone's HEICs open fast ...). With JPG I've chosen to use the DR400 setting, but the problem is still there. For "more important" photos I of course use the RAW format. Regards, T.
