Hi all,
Have a problem with my X100T, the camera is 16 months old. The ability to pre-focus by depressing the shutter half way and get a green square in the viewfinder / lcd has vanished, no matter what focus setting I change. User error or time to go off for repair??
Have you checked the EVF/LCD options?
You can select or deselect things to show or not.
  1. Select [DISP. CUSTOM SETTING] in the shooting menu.
  2. Highlight [OVF] or [EVF/LCD] and press [MENU/OK].
  3. Highlight items and press [MENU/OK] to select or deselect. Selected items are indicated by a check mark.
[FRAMING GUIDELINE] [ELECTRONIC LEVEL]
[AF DISTANCE INDICATOR] [MF DISTANCE INDICATOR] [HISTOGRAM] [APERTURE/S-SPEED/ISO] [EXP. COMPENSATION] [PHOTOMETRY]
[FLASH]
[WHITE BALANCE]
[FILM SIMULATION] [DYNAMIC RANGE] [FRAMES REMAINING] [iMAGE SIZE/QUALITY] [MOVIE MODE & REC. TIME] [bATTERY LEVEL]
