I just purchased an X-T2 and had a couple questions for those of you that have one regarding using it to shoot video.
-What is the best film simulation mode to use for a flat profile suitable for color grading. I don’t have an external recorder to records F-Log.
-I have the Power Booster Vertical Grip on order, which comes with a power adapter to charge two batteries while inside. Can I use this power adapter to power the camera for continuous filming, or do I need to buy another power adapter to power the camera directly for this?
I would say the best film sim would be to start with a Provia base and then bring down your highlights, bring up your shadows, bring down your color intensity and sharpening to end up close to flat.
Also, yes, you can power the camera with the adapter when the grip is attached to the camera.
