Damaged 60mm macro
Gigas
My macro lens got damaged and now the focus ring is sluggish and noisy. Is there anything I can do to unscrew the focus ring to push out the pressed part?
Unless you have precision press machine, I wouldn't advice you to try yourself.
I would stop using this lens immediately and send it in for checks and a focus collar replacement by Fujifilm.
If you continue to force the focus collar, you may damage something internally. It's probably just pinched focus assembly at the moment but even then it may cause metal shavings in your lens.
    • Is there a way to keep your menu selection on the last option you used? For example.  When I select MENU the cursor defaults to MY Menu.  I scroll up to IQ settings, make a change, and return to shooting. When I press the MENU button again the cursor is back to MY Menu.  I really want it to stay on the IQ setting I was last using (or any other Menu setting). It's a PITA to keep scrolling up and down, back to the previous setting.  (Note.  My Canon Menu retains the position of the last option I was using). Thanks in advance for any help.
    • Im not partal to any brad, just opted to try these based on apparent price / performance.  I'm always looking for best bang per buck, hence Fuji I guess - haha Reliabilty does not concern me, as I always shoot to two cards for pro work (and burst shooting is not a part of that). Made sense for me to get the cheapest / fastest CF cards for hobby shooting.     I just got a Sabrent Rocket V60 512GB cheep (as the back-up card).   As long as neither of these freeze the camera I hope its a cheep solution for my needs. (AB AV Pro SE 512Gb and Sabrent Rocket V60 512GB).  Half a gig of redunat storge for $200USD is something I can live with. (Especially considering I can bust the hell out of the Anglebird). Cheers, Tomek
    • Would using an external charger be of benefit to the batteries life? I appreace it can be faster, but I doin't mind pluging in the camera over USB to charge. Does charging via the camera do as good a job as lets say the fuji's own external charger? Does the camera stop charging once the battry is full and not over charge? I couldn't find these deatails in these forums or in the manual. Thank you!   Image below shot on X-T2 in a sunny studio.
