Does anyone have any experience using the Nikon 35mm f/1.8 or Sigma 35mm f/1.4 Art on the X-T2, X-T1, or X-Pro2? I am trying to decide if I am going to purchase one of the Fuji 35mm lenses while they are on sale, or if I should hold off and adapt my Nikon mount 35mm lenses.
I am interested in your thoughts on IQ, DOF, bokeh comparisons etc. between the two Fuji lenses and the adapted Nikon mount lenses. Also, if you have used these lenses on your Fuji, what adapter you have used.
Just be aware that you will lose the aperture control since there are no connectors between the Nikon F mount and Fuji XF.
There are no smart adapter for the time being, so all of them are only various level of plastic/aluminium quality and shouldn't cost you more than 20$ most of the time.
In all honesty, I would rather use the Fuji 35 lens, first of all, it will be smaller and light than any other contraption you could find. You wouldn't lose the AF nor the aperture control either. And the 35 F1.4 is still one of the most beloved lens on the Fuji, you will not go wrong with it.
Thanks darknj. I am now leaning towards just getting a Fuji 35mm lens.
    • Hey everyone, I am new to the fujifilm system, and I just received my X100vi about 15 days ago, and yesterday I noticed that ISO and exposure dials are acting up. I spent hours watching YouTube videos and reading forms without finding any solutions. Using ChatGPT or Gemini also didn’t help. My issues are the following: If I want to set my ISO at a specific value then the camera LCD/EVF shows a totally different value. For example, I have shutter manual, aperture manual and ISO dial at 6400, the camera shows ISO at 4000, when I take pictures it will show ISO at 4000 and not 6400. When I try to choose another ISO value it will skip some of the available values that are shown on the dial. Another issue I am having is when my exposure dial is not set at specific value, then I cannot set ISO to Auto no matter what value I select on the dial. If I do select the different exposure compensation values, then I choose A for ISO, the camera will activate the front commend dial to manually change ISO values. To get in Auto ISO, the shutter speed cannot be set in auto and the ISO dial should be set at 125, when I turn the ISO wheel, it seems like the numbers are misaligned by one value, If I put the dial on A with shutter speed manual, then it will trigger the front commend dial. The other issue that I am having is when I have Aperture, shutter speed and ISO on manual, If I change the exposure dial compensation + or - , it actually changes the exposure of the picture as well as the ISO value, which as I understand, if Camera is in full manual, the exposure dial should do nothing. The last issue that I am having, if I do have ISO in manual at a set value, and adjust exposure compensation dial, it alters my ISO instead of my shutter speed or my aperture, even though ISO is in Manual and the other two dials are in Automatic. I am not really sure if all of this is by design and I am just not understanding how everything works together, but it seems really odd how everything changes. Resetting the camera settings didn’t help.
