Fuji X-T1 rocks lonestar le mans!
Way too much fun with the x-t1 and 50-140 and TC 1.4x at the circuit of the americas - super fast sports cars were so much fun to shoot!  New blog post is up!
https://fujisports.wordpress.com/2016/09/19/fuji-rocks-lonestar-le-mans-09162016/
There was actually a big fujifilm tent there from the biggest camera shop in Austin.  I got to hold an x-t2 in my grubby paws with a 100-400 attached ... oh my ... it only took 10 seconds to figure out that the canon gear needs to be sold to fund some more fuji gear! That x-t2 was awesome for the short time I spent with it :-)
