As you may know, we have an official forum meeting with members of the German Fuji X Forum at this year's photokina on Saturday, 24NOV at 1 PM. There will be a guided tour (in German) around the Fujifilm booth which includes an invitation to the inner sanctum. Free drinks, too, I guess.
As you may also now, I'm offering a free Fuji X Secrets mini workshop right after the tour around the Fuji booth. The workshop starts at 2 PM and lasts till 4 PM.
This offer was limited to 7 delegates, but since I have already received more than 7 registrations, I've decided to offer a second session of this workshop for another group of delegates. Session 2 begins at 4 PM and lasts till 5:30. This gives everybody sufficient time to make it to the city in order to join the official Fujifilm photokina photowalk that starts at 6 PM at the steps of the Cologne cathedral.
Both sessions will be conducted in German and are open to everyone who owns a Fuji X camera. It's a short and free stunt, but it's still Fuji X Secrets, so don't expect a fluffy marketing or advertising presentation. Instead, we will cut right to the chase. If you want to join, register here: https://www.eventbrite.de/e/fuji-x-secrets-free-photokina-2016-registrierung-27762712019
Please be aware that session 1 is practically sold-out, so your registration will automatically be for session 2.
Edited by flysurfer
