Hello . I was a fuji xt4 user in the past and now i had replaced XT4 with X-S20 . The one feature in XT4 to choose film sim in sd and f-log in hdmi  is a very useful feature for me.  But in  new camera bodies that feature has been removed . I hope to see that feature again in X series bodies
