Hello, fellow x-shoters.
I am preparing for a project that would involve a bit of external flash triggering at the rear curtain sync.
Are my options limited to ttl flash, set to ttl mode, rear curtain sync turned on and then the flash set to manual mode and used as optical master, or are there any radio triggers which could pretend to be flashguns and trigger the external unit with the second curtain?
As far as I am aware, at this time your only radio trigger option is the Cactus V6 / V6 II, which allow you to manually set a flash delay, allowing you to fake rear curtain sync. For example, by setting a flash delay of 1.8 seconds and setting your  shutter speed to 2 seconds, the flash should trigger just before the rear curtain starts to close.
Exactly, don't know of any other solutions either. I have the Cactus ones and they work just fine.
    • Australia, SE Asia and South Africa, that is quite an itinerary in front of you. You are going to make some folks jealous 😀. There are places especially in South Africa, that will rent lenses to you while you are visiting. That saves a lot of wear and tear on your gear and gives you some peace of mind regarding damaged/lost equipment. Take this advice with the necessary heaping shovel of salt, but from what you are describing, try a wide zoom, a medium normal zoom and a long prime. As mentioned, you may be able to rent one or more of these in each region and instead of lugging gear, stuff the luggage with memory cards and batteries with universal chargers. In the mean time, show us some autumn shots! edit: Add a few smart adapters to the list, then you can use cough third party cough lenses as well, all while traveling light.
    • Appreciate your thoughts! Glad to know you feel I have good bandwidth with my current lenses. I am just eager to get the best out of my Fall foliage trip and also get ready for a trip to South Africa next year. Guess I do need a super zoom lens. Mike
    • Welcome to the forum. The Sigma lens is fairly new on the scene, the Fujifilm lens has been available for a while. Here are a couple of reviews that may help you decide: https://petapixel.com/2025/03/13/sigma-16-300mm-f-3-5-6-7-dc-os-review-a-long-awaited-return/ https://www.dpreview.com/reviews/field-review-fujifilm-xf-70-300-f4-5-6-r-lm-ois-wr The Chris Niccolls mentioned in the reviews is the same person. Please read these closely, especially if you are essentially wanting to get the lens, learn its basic familiarity and then take it on your trips. It can be really frustrating to find out during the journey that some of the negatives are vastly out weighing the positives. Are you wanting to try saving some weight by taking just one lens, a super zoom lens? If not, you already have the wide end covered with your present line up.
    • Hi friends I am a newbie to photography and to Fujiworld. I travel a lot for fun and enjoy wildlife and nature. After several years of taking photos with iphones, I bought a Fuji XT5 a few months back. I currently own only these two lenses: Fuji 23 mm F2 R and a Sigma 18-50. For an upcoming fall foliage trip and also Austalia/SE Asia trip, I would love to get a good telephoto lens. I am looking at Sigma 16 -300 or a Fuji 70 to 300. What would be your choice? Is there any other versatile lensI could buy for my trips?  Appreciate your advice!! Mike
    • I have just read this. All the XT cameras I have owned stop down with a half press of the shutter regardless of whether AF-C or AF-S is selected. This includes my X-T5, which I have just tried with all three shutter types. I haven't experienced your problem. What happens when the button is fully depressed is another matter. I don't have enough knowledge of that. I don't own an X-T50, so I can't say if it is the same.
