X-H2s ,CF card: Lexar Pro Silver CFexpress Typ B 128GB,   Recording was shot, saved, camera didnt show any error.  However, i checked recorded files and  some of them been damaged!  some videos goes halfway and then screen is freeze, but playback run.. weird. The length of the video corresponds to the recorded footage. Has anyone figured out  what is happening ? thanks a lot... I  sent back the card, to get new , but i m worry  it could be error in my new X-H2s :(.   Here is the damaged file :  https://we.tl/t-SAjkC4hPYz.   (no viruses dont worry :D)Firmware is updated  in camera, also lens.
Please help! :(
also picure  of how the file looks like in editor.  :/
Edited by michaelradacz
I got a CF Ccrd reader..  the file is already damaged ( screen get freeze) when you play it in camera...   Im  trying to figure it out,  but seems like no one had same problem..   I use backup on SD card,  the file there is OK.  so its only problem with CF card or CF  slot in Camera...
Ah - I misunderstood - hopefully its a problem with the card and not the camera - have you tried a different card?
  • 1 year later...
Hi,
I know this was last year but did you resolve the issue? We have had a couple of times this has happened at my company. Each time the file size suggests it is all there based on length of recording however after a few mins the screen freezes.
Any advice would be greatly welcome.
  • 8 months later...
On 12/2/2024 at 2:47 PM, mav1712 said:
Hi,
Hey , same problem here - did you find the cause or what the issue was? Was it the SD / CFast card?
Thanks
    • (Open Thread) Not a winter landscape, but still cold.
    • agreed on the upload but based on the location and number it sounds exactly like the storage slot 1 status icon
