X-T2 displays ND in top left corner of viewfinder/Backscreen
More testing of lenses today. Nikon 70-200 f/2.8 IF ED VR (same applies to VR II) - dreadful. Heavy vignette at all focal lengths and apertures. Obvioulsy fine in 35mm mode. Nikon 70-200 f/4 - some vignetting at full frame (similar to 24mm f/1.8 and Sigma 105 f/2.8). Perfect in 35mm mode. -
