I bought a new Fujifilm X100F from B&H in late August 2019 and also got the five year warranty for $129.
Fast forward to late spring of this year and the camera started to have issues. The AF-M/S/C switch not longer switched between modes. And everytime I took the battery out it lost all settings.
I contacted the warranty carrier, Allstate and they had me send the camera into them at their expense.
About ten days later got the camera back from Photo Tech Repair who is a authorized Fuji repair center in New Jersey. I did not have to pay for return shipping BTW.
All the issues have been repaired including a sensor cleaning. Weirdly the receipt does not say what was fixed but I bet that one of the boards was replaced.
I have no idea how much this repair would have cost but I bet that it would have been a lot more than $129.
I am very happy with the service I received and am very glad that I bought the extended warranty.
Zack S
Edited by zaax
  • zaax changed the title to B&H extended warranty was worth it
    • The backslashes you are referring are just symbols denoting path.  Once you import into these LUTS into Davinci Resolve those backslashes are removed by default and you only see is the true file name which has no backslashes.  Convince yourself of this by opening the LUT folder from the Davinci Resolve Project Settings.  Do you see any backslashes in those LUT names? Of course not.  The only name you see is the one that has the underscores and the periods. These LUTS work as designed without having to change any path names.  However, they need to be set up properly set up through CSTs and by what is supported in Davinci Resolve.  Hence, the FLog2C LUTS cannot be used because Davinci Resolve does not support Fuji Gamut color space and the FLog2C gamut. Alternatively, Davinci Resolve does support Flog2 because the color space for FLog2 is Rec 2020 and there is an FLog2 gamut. If all you are doing is changing the path names then most likely you are not getting the correct results.
