Looking for some advice.
I have the opportunity to buy a X-H1 with 30,000 actuations/shutter count.
Cosmetically, the camera looks almost new.
The seller reports absolutely no issues with the camera, that it’s been used primarily in studio.
Should I be concerned about the actuations/shutter count?
…is 30,000 too high?
Many Thanks!
The seller sent me a screenshot of the JPEG EXIF information report… 30,000 shutter count/actuations is what was reported.
…see attached
No mention if it was mechanical or electronic.
The seller did indicate that he used a mix of mechanical and electronic.
Edited by Canuck57
