I am fairly new To Fuji cameras although I have a lot of experience with Medium format and 35mm. With Medium format/35mm I would often use F8 or F11 to maximise my depth of field for an image. I also use a tripod to minimise camera shake.
Can anyone suggest the best F Stop to maximise depth of field on Fuji X100 cameras?
Thanks
Frank
It would be easy enough to say 'set it at f14 and best wishes'. That would be doing you a dis-service.
APS-C sensors are different than medium format or 35mm film, some like to think of them as similar to shooting slide film -- exposure seems to matter more than dof, but that also is a much too big of a generalization to go by. Just like the Sunny 16 rule and the hyper-focal distance rule guidelines your teachers taught you way back when were starting points to build from, one decent way to get going to to remember every image setting is different. That may seem too vague, but just start from scratch, so to speak; pick out several familiar scenes you favor, put the camera on a tripod and shoot differing f-stops. Digital film is very, very, very cheap. After a while, your intuition will take over and you will be getting the dof you want.
One thing you might not want to consider yet, different lens can go deeper than others -- deeper as in in higher numbered f-stops before diffraction occurs, you have to read reviews to know which ones will and will not, so to speak. Focus stacking is easy enough using digital files in an external editor, your camera will need to get the frames manually though.
Edited by jerryy
I use f7.1 or f8 for max dof on my X100v.
The APSC sensor gives greater dof than full frame (35mm equivalent).
If you want to see what is in or out of focus then shoot manual focus with focus assist set to red highlights, you will see clearly what is in focus. The X100v even displays a scale in the EVF indicating the focus distances.
Enjoy your X100.
I try not to shoot more stopped-down than f/8, but I'm sure f/11 would be perfectly acceptable for most people/uses. I would expect to see the effects of diffraction at f/16 (and I'm sure there's a good reason why they didn't include a stop at f/22). Throughout most of the aperture range, subject distance is going to have a much bigger effect on depth-of-field than aperture setting. If you want maximum depth-of-field AND performance, use hyperfocal-distance focusing with an aperture in the middle of the lens's range. Given that's it's a 23mm lens, hyperfocal distance will be usefully-close to the camera.
Edited by dbell
    • X100vi Godox xpro trigger  godox v1 flash  the test button on the trigger fires the flash. The camera seems to see the trigger attached and on, but the camera doesn’t fire the flash. Is it a setting or is there something wrong with my camera? I was at a workshop and borrowed a pocket wizard that worked with my Nikon, but not with the Fuji.
    • I also have a Fuji XT-5. Mine doesn't have these problems. You should send it in for servicing.
    • I have owned the XT5 now since its release and I still have random shutdowns, difficulties with low-light - ISO performance and hard to get focus. How long can I wait before giving up and changing brand.  I also use a GFX 50R. Lets not go there.
    • Prior to this I had a camera that would connect to my Oneplus12 (Android 15.0.0.840) via bluetooth. I did the update all appeared to be well though I didn't check the bluetooth connectivity. Then I saw the 4.3.1 bugfix update and tried to apply that through the X app ( version 2.5.1(1) ). Was told I needed to re-pair my camera. Tried to and couldn't. At the point where I have to confirm the security codes I confirm the pairing on the phone, then on the camera and the camera display sits waiting for the pairing confirmation and there's a message on the X App that tells me there was a communication error that prevented pairing. Eventually camera disconnects from phone. If I try confirming the camera then the phone I end up in the same place. I've deleted and reinstalled the app, restarted the phone. Nothing seems to make any difference. I did the update to 4.3.1 via SD card and nothing appears to have changed W.R.T bluetooth. Any ideas?
    • Hi everyone, hopefully there is is someone out there that has experienced this before me and has a solution I've recently purchased a Camera Foundry Cineback in an effort to streamline my setup a bit for video recording. Before I was using my XH2s and a Tascam Portacapture x6 with their own internal power sources but with the Cineback I'm able to connect the two devices to the same battery via USB-C. My problem is discovering that when both the XH2s and the X6 are plugged into that shared USB power source, I get a clicking/popping noise on the recording and headphone output from the XH2s. The output from the Tascam is clean on both the headphone out and the actual line output I'm using the feed the XH2s. This isn't necessarily confined to the Cineback device either. I have a USB power supply that plugs into the wall with dual USB-C outputs and I get the same audio issue when connecting the Tascam and Fuji to run off that power souce. If I use two different USB power supplies, either a second "wall wart" or running one from the Cineback source and the other from the wall, I have no issues. I've also tried replacing my Tascam recorder with a Zoom F6 to see if there was an issue with the Tascam device, but I get the same problem with the Zoom F6. Is this an issue with my XH2s? Some sort of ground loop issue? Any help would be appreciated!
