On 5/21/2023 at 7:51 AM, bergat said:
Whath do you think is about, Patrick ?  Is it a new version of Cam Remote?
It is, among everything else. Works great on my XT5.. paired easily and the connectivity seems more robust and somewhat less fidgety than the old app.
