Hi Guys.
I just have one 75 mm lens for fuji. For my needs (video + landscape photos) I want one more ultra-wide lens:
  1. 7Artisans 25mm T1.05 APSC CINE
  2. Wait for Future Tamron's 11-20mm F2.8
A noob question, but how do Cine lenses compare to regular lenses in still photography? I know that focus will be manual and it doesn't bother me, but what about IQ and sharpness?
Thank you in advance
Edited by Sirius
Welcome to the forum.
The 7Artisans’ lens is wide, but if you are looking for ultra-wide, think of 16mm as being  “long”. Tamron makes great stuff, but there are many excellent ultra-wides available now, it just depends on what you want.
I have one cine lens and have used several others, their iq is fantastic and are every bit as sharp as one could ask out of them. You do have to get used to the gears (on the focus and aperture rings for the pullers) and using t-stops instead of f-stops, but everything works smoothly and the results look fine. They do cost more, sometimes a lot more, than their non-cine equivalents.
    • Hey everyone, I am new to the fujifilm system, and I just received my X100vi about 15 days ago, and yesterday I noticed that ISO and exposure dials are acting up. I spent hours watching YouTube videos and reading forms without finding any solutions. Using ChatGPT or Gemini also didn’t help. My issues are the following: If I want to set my ISO at a specific value then the camera LCD/EVF shows a totally different value. For example, I have shutter manual, aperture manual and ISO dial at 6400, the camera shows ISO at 4000, when I take pictures it will show ISO at 4000 and not 6400. When I try to choose another ISO value it will skip some of the available values that are shown on the dial. Another issue I am having is when my exposure dial is not set at specific value, then I cannot set ISO to Auto no matter what value I select on the dial. If I do select the different exposure compensation values, then I choose A for ISO, the camera will activate the front commend dial to manually change ISO values. To get in Auto ISO, the shutter speed cannot be set in auto and the ISO dial should be set at 125, when I turn the ISO wheel, it seems like the numbers are misaligned by one value, If I put the dial on A with shutter speed manual, then it will trigger the front commend dial. The other issue that I am having is when I have Aperture, shutter speed and ISO on manual, If I change the exposure dial compensation + or - , it actually changes the exposure of the picture as well as the ISO value, which as I understand, if Camera is in full manual, the exposure dial should do nothing. The last issue that I am having, if I do have ISO in manual at a set value, and adjust exposure compensation dial, it alters my ISO instead of my shutter speed or my aperture, even though ISO is in Manual and the other two dials are in Automatic. I am not really sure if all of this is by design and I am just not understanding how everything works together, but it seems really odd how everything changes. Resetting the camera settings didn’t help.
