I know Fuji XT-1 is not an ideal camera when it comes to video quality. But It's nice to have it there, and I recently discover that there's no way I can shoot manual K white balance in video. Also not sure if it's just me but when ur in Continues High mode, only the first shot come out as the K white balance that I set, but the shots after is not affected. Weird? Any thought? Or I'm just missing something here? Thanks
Those are interesting questions.
I have found that the auto white balance on my XT1 to be better than my past Nikon full frame bodies, so I haven't had the need in my photography to pursue a custom white balance.  I do have a white card for setting white balance on my XT1, but I have not tested video custom white balance or shooting in a burst mode with a custom white balance.  But it makes sense when shooting still images that once a custom white balance is set, it should apply to every photo you take!
