Hi,
I recently traveled to Berlin. Together with my Fuji XT-1 of course! Some minimalistic architectural photo's from the immense Tempelhof airport. Such a weird, but also big, impressive, piece of architecture with a lot of historical background, but in modern times it is a great escape from the city to many people.
Just wanted to share three of my photo's, so here goes.
front
radar
view
more photo's @ www.robertdoeleman.com
